Wetroom Store - Network Wetroom Suppliers
Discuss Looking for a piece of kit in the Industrial Electrician Talk area at ElectriciansForums.net
W
wattsup
Jeez I get some enquiries lately...
I need to price for a warning bell when demand exceeds 60amps ac.
I guess I would need to wire an ammeter, which somehow sends a signal to a relay which in turn would trigger the bell. Is there such a thing available, how do you search for such a device? Or will it need to be made to order?
I've found a wireless device where a couple of magnet type thingies fit arround supply cable, but it just gives a remote visual on current drawn and I guess it wouldn't work if transmitting through several walls.
What would the device be called ? Anyone any ideas for search queries
Instyle LED Lighting Specialists UK
M
mdshunk
  • #2
Current sensing relay. Run the conductor being monitored through the "doughnut" on the relay. I used one of these recently to turn on a beacon when a conveyor motor was running:
AC Current Sensing Relay
R
rumrunner
  • #3
DIN Rail Timers, Voltage and Current Sensing Relays Heres a link to a company i have used in the past for various stuff ,to use the current sensing relays listed you will need a ct,they shold be able to help with those as well or rs comp ,they might even have similar relays
have fun
Spudmiester
  • #4
RS should do something.
There are panel mounting ammeters with high/low relay points. Or there are pump monitors for over-current or under-current, which are a bit like the thing MDSHUNK suggested.
W
wattsup
  • #5
Thanks guys,
md I like that piece of kit, exactly what I'm looking for, all bundled together nicely. Can I connect 230v?. Without emailing them I can't find a price either.
CK Tools :) The professionals choice when it comes to Electrical Tools
Reply to Looking for a piece of kit in the Industrial Electrician Talk area at ElectriciansForums.net
Aico 3000 Range
Top Bottom
