Electrical2Go - Online Electrical Supplier
Discuss Looking for advice with a self made c/u in the Electrical Forum area at ElectriciansForums.net
Afternoon, I've spent the day looking for an ip55 or above 6way single phase c/u... Its to be installed inside an enw substation and from past experience they don't expect the metal enclosed c/u, so long story cut short, I've got an ip65 enclosure with dim rail but I'm not sure how to fit a neutral and earth bar as its not come with them.. .. Any advice would be much appreciated
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
  • #3
That would be perfect however I'm doing the install tomorrow... It should never really have been left for me to order but I got it dumped on me this morning ... I think I've resolved it anyway, I've taken a neutral and earth bar out of an old c/u and attached one to either side of the box with a roofing bolt and nut
Midwest
Do you not have to have some form of ‘certfication’ (not quite the right term) to produce or provide such a product?
Strima
I was just thinking the very same.
  • #8
Yes that's a very good point ,I'll install it tomorrow but I've ordered the above link, so if something comes back should be an easy change
  • #9
The long bar is offset because the terminal hole was larger than the others so the roofing bolt would fit through without drilling the hole
telectrix
Mentor
But don't you have en externally exposed bolt head connected to neutral?
useful test point, or bit of gaffer tape will sort out.
Yes I'm hopeing to cover it or failing that I'll remove it and just leave it inside loose, not ideal
Nylon nut and bolt?
littlespark
How does this work out with the “same make if breakers in the same make of board” regulation?
DPG
I think he was replying to littlespark's comment.
I have actually considering I work for the electricity network... Clearly you haven't because any dno set out the standard regs plus there own twist ie ip ratings ect..
All my work is at power stations and occasionally subs but I'm normally on HV/EHV with transformers and switchgear. I should have put a ;) on my last post as I've seen some of the work on sites that certainly wouldn't come up to current, or for that matter, previous regs. Some of it is quite new install stuff too. Not by me I should add :)
  • #24
Fair enough, thought there was a snide comment there ..... I work in power stations and subs lv and hv, I do the lv terms, hv terms and small wiring ... I work under enw, ukpn npg and wpd and all have had different spec
No, not directed at your work at all. It was towards the normal 'standard' of site engineer installed equipment. I've yet to come across a site engineer who has any 'normal' electrical qualifications. Most of them would believe you if you told them the 14th edition was the latest release :eek:
Just put the whole thing inside a bigger enclosure;)
  • #28
I've found a cpc on route tomorrow that have 4mm plastic bolts... Going to put them in...... Lesson learnt though, not ordering materials for a supervisor last minute ever again
Might be a bit late for this one but you could use some din rail terminal strip for a neutral bar (if you have the space to fit it somewhere without it being exposed on the front cutout)
freddo
Supporter
All that effort messing about with neutral bars when you could have just stuffed all the circuit neutrals together into the RCDs load side neutral terminal! :D
Wetroom Store - Network Wetroom Suppliers
Reply to Looking for advice with a self made c/u in the Electrical Forum area at ElectriciansForums.net
Top Bottom
