Discuss Looking for advice with a self made c/u in the Electrical Forum area at ElectriciansForums.net
All my work is at power stations and occasionally subs but I'm normally on HV/EHV with transformers and switchgear. I should have put a on my last post as I've seen some of the work on sites that certainly wouldn't come up to current, or for that matter, previous regs. Some of it is quite new install stuff too. Not by me I should addI have actually considering I work for the electricity network... Clearly you haven't because any dno set out the standard regs plus there own twist ie ip ratings ect..
Correct rough adBut don't you have en externally exposed bolt head connected to neutral?
Rough as a badgersuseful test point, or bit of gaffer tape will sort out.
Rough as a badgers
Reply to Looking for advice with a self made c/u in the Electrical Forum area at ElectriciansForums.net
