Discuss Looking for wiring advice in the UK Electrical Forum area at ElectriciansForums.net
Please see attached photo.
This is the wiring in our bathroom. I've just removed the light fitting that was installed when the house was built and this is what is behind it. It doesn't look right to me. It appears the original fitting was installed using the black, blue and grey wires, but I didn't take proper notice of how as I wasn't expecting to see something that appears to me to be non-standard.
Does anybody have any idea why this would be done in this way? Is it safe? Can I just wire up a new light fitting to those wires?
Thanks in advance.
You will need a multimeter to work out which is perm live (most likely the browns in this case) which is swi live and which is N
Never ever assume what does what
Get a sparks in if you are not completely happy
There could be a few reasons this has been done this way. Most likely to do with an extractor fan, since its in the bathroom. Get a qualified electrician in to check it out and advise you on whether its correct and safe.
There is an extractor in the bathroom, so I guess that's the reason here. I think getting a professional in is the best advice, thanks for your help.
could always dig up pete 999. he very good spark and in your area.
If you can get all those wires and connectors inside your light fitting, fine.
If not, you really should put them all in a Junction Box and come out with a short length of flex to the fitting.
Reply to Looking for wiring advice in the UK Electrical Forum area at ElectriciansForums.net
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hi, I'm replacing a light fitting in the bathroom but the wiring is confusing me, black brown and grey? Is black neutral and brown live in this...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
