Bulk Workwear - Clothing Suppliers for the Whole Forum Network
Discuss Loop Ceiling Light in the Lighting Forum area at ElectriciansForums.net
Hi,
I am installing a new ceiling light. I know there s the wires from previous light and wires to next light and switch cables . One of the sets has two brown wires so not sure about these . Any help would be great . ThanksIMG_20190815_115606.jpg
Electrical2Go - Online Electrical Supplier
Pete999
More than likely, that cable is the Live and SL to the switch
Spoon
Mentor
This is a pure guess and only way to be sure is to test the cables, but I'm guessing as:
The cable with the two brown wires is the switch wire and the other 2 cables are 'feed in' and 'feed out' to next light.
B
Bobster
I would agree with @Spoon
Do you have a picture of the terminals on the new light fitting? Would make it easier explaining what goes where.
Do you own any equipment to test?
Risteard
Twin brown is always the switch drop (or strappers - but clearly not on this occasion as this is at the luminaire).
Spoon
Mentor
I hope you are doing all of this with the power switched off.
Take the switch off the wall and look at the cable going to it. Does this have 2 brown wires?
  • #9
The black connector came with the light fitting. Didn't seem to be able to accommodate all wires and no place for loop wires so I ordered the two other ones below ( white and blue). If using the white one I was going to let it sit in the light fitting as the fitting is big enough ( would that be ok?) . O tested the wires with the multimeter but not sure if I did it properly . Thanks again
DPG
Patron
Are you Bob Vance of Vance Refrigeration?
As you are in Ireland I believe what you are doing is illegal and could land you with a four figure € fine best to call in a registered spark.
Matthewd29
Not quite, you are allowed to change fittings/fixtures and even move lights depending on the amount of alteration taking place to the circuit. But we clearly have an issue won the electrical competence here and I would also advise just to call an electrician buying all of that is false economy just pay someone for half an hour's work
Risteard
Indeed, as @Matthewd29 has pointed out minor works (http://www.walshelectrical.ie/electrical-services.html#minor-works) are not illegal. However any work in a special location (e.g. bathroom) are always Restricted Electrical Works and never minor works, so for example replacing a pull cord like-for-like is a criminal offence if the person doing it is not a Registered Electrical Contractor (REC).
The photograph shows that the works in question are not in a bathroom, however.
Paignton pete
R u still hung over. There are regulations in place that prevent work on electrical installation if under the influence of alcohol or other substances with the potential to limit mental or physical aptitude.
No problem with you changing a light fitting or doing small simple electrical jobs in your own house, but do it sober.
Aico 3000 Range
Reply to Loop Ceiling Light in the Lighting Forum area at ElectriciansForums.net
Top Bottom
