Discuss Loop in and out at switch in the UK Electrical Forum area at ElectriciansForums.net
Hi, looking to wire 3 gang switch loop in and out method
1st switch is One way
2nd switch is One way
3rd is Two way
With my loop in, I go from 1st switch COM and link to 2nd switch COM then link to 3rd switch L1, all neutrals in a wago with my loop out in L1 also, then 1st switch T+E to light from L1 and neutral to wago same with 2nd switch, then my 3rd switch T+E from light to switch Brown to L2 and Blue to wago then 3 core to 1 gang 2 way Black to COM, Brown to L1 and Grey to L2
3rd is Two way
are you not up to speed on that system ?
3rd is Two way
looks right from here.
3rd is Two way
I hope you're not using a 16mil backbox? :)
Sorry peach is grey hahahaha
That looks correct (except for the cable colours!!)
I take it if your looping at switches COM is always for 1 way and L1/L2 for 2 way
Sorry not done much looping at switches
Yes, when wiring switches whether you are looping at the switch or not, for that particular method the switch terminals (C L1 L2) will have the same functions (L or SL or strapper).
If you are looping at the switch then the neutral will be jointed in the switch box but not at the switch terminals.
Reply to Loop in and out at switch in the UK Electrical Forum area at ElectriciansForums.net
Hi I am trying to replace my old white light switches for nice chrome ones but the wires are all red but the new switch has only l1 l2 top and...
I threw away an old knackered light switch and now need to replace it. It had 4 terminals (L1, L2, L3, L4) and is fed by two blue and two red...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
