Discuss loop readings in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
carlhenry01
Hi, Part P newcomer here. When taking for example a loop impedence reading on say a ring main, linking live/neutral together you divide the result by 2 to give a reading for each cable because they are the same csa2 but how do you caculate for a live/earth reading when the cpc is a different size? Also information on how to do an insulation test on SELVs or flourescent lighting circuit without linking evey fiitting out?:)
Yes sorry I meant a continuity test when cpc is different size to live conductor but the lighting circuit question remains the same.
Carl.
for the ring
like Ian said, its continuity you are looking for
do end to ends
r1 (line)
rn (neutral)
r2 (cpc)
link incoming line to outgoing neutral and vice versa
reading between line and neutral at sockets is r1+rn divided by 4
link incoming line to outgoing cpc and vice versa
assuming 2.5/1,5 tw&E,
2.5 divided by 1.5 = 1.66, so r2 value should be 1.66 times higher than r1 and rn value
you should read r1 + r2 divided by 4 at the sockets, highest reading is your (R1+R2) for the ring (normally at a spur)
your readings should be +/- 50 milliohms for each socket
Reply to loop readings in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In my line of work it's very rare that I ever have to change a DB. I'm largely in maintenance; occasionally have to add new circuits etc. so in...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Slightly strange one this, replaced a few socket fronts in a dining room today, all wiring original but new plasterboard on a studded wall. Its a...
Hi all, I've just tried wiring an indesit IB65B60 induction hob. I read the instruction manual and it said for 240v connections to put the...
4K
