Discuss Loop resistance & cvt in the Industrial Electricians' Talk area at ElectriciansForums.net
speedtronic
1. To measure loop resistance of small motors rated in KVA, we simply use a multimeter to get required results while for large motors/equipment rated in MVA we have to use a test set through which we apply some current & get the results. Why doesn't multimeter work there?
2. What is the purpose of capacitors in capacitance voltage transformers?
Moreover, what is the difference between a PT & CVT?
Reply to Loop resistance & cvt in the Industrial Electricians' Talk area at ElectriciansForums.net
Two related questions in 1, if anyone is up for helping! (i) When electricians install supplies, is there anything in the regs that says how many...
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
I have an original 250w glow plug in my 8yr old pellet boiler that's used to light the pellets during the start up phase on my boiler. The boiler...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
I've managed to mainly fix a Megger 1502 MFT that was so far out of calibration it got laughed out of a tester day. I have high current loop. rcd...
