Discuss Low voltage halogen equivalent??? in the UK Electrical Forum area at ElectriciansForums.net
Joe S
I have a customer who has in excess of 25 low voltage down lights that are on 24/7. They have a condition where they can't tolerate LEDs or CFL lamps and GU10's aren't bright enough. Does anyone know of a make of bulb that runs cooler than most as I am changed lamp holders every 6-8 mths. I've tried all manner of holders and ally backed lamps but in the end the wire burns off the terminal. They are concerned about the reliability of the materials but I have assured them that it is all good bits and that no one usually has their lights on 24/7. The heat generated is huge.
Any ideas greatly appreciated.
P.s
I know the repeat work is great butI would also like to know if there is an answer.
Cheers
joe
I have tried mate. They won't even have led under cupboard lighting which isn't seen directly. They have 12v cabinet lighting which is also popping all the time due to heat build up. It feels like trying to reinvent the wheel on this job as the only light they can tolerate is l.v halogen.
The down lights are traditional with cans and lamp set up. Up stairs there is insulation in the loft but not on the lights as I've pulled that off a few years ago. There is a light breeze through the downstairs ones but the house is very warm anyway. The under cabinets are surface mounted units. I have tried all methods with no luck. I even tried main role lights but they weren't bright enough. The issue is I never fitted the lights originally and have inherited it about 7 years ago. I have found some LEDs to be very closely matched to halogen for colour but better output. This customer can't stand the light they give.
Had a quick google, all I can find is SAD and Epilepsy. Neither of which sound like your problem. Maybe ask them what the problem is and do some research into the condition.
I appreciate the help. If I'm honest I think it's a little in the mind as there is a lot wrong with them. I maybe wrong but I've never come across this situation before and the golden rule 'customer is always right'.
I agree but they have been good customers to me and I still believe in loyalty and will do what I can. I'm out of options so I'm probably going to end up putting lower wattage lamps in and seeing they get on with it.
I know that photosensitivity is a problem for some people.
I personally can tell when I'm under a LED light, the frequency is perceptible when viewing moving objects.
What make LEDS have they tried ? As Andy said previously about strobing effect , noticed it myself on certain types .
Have you ever fitted an Enlite 8w integrated fitting , I find the light to be very halogen like .
Maybe try some different types of LED lamps in a room (but don't tell them they are LED) as it maybe psychosomatic?!
I'm guessing they are wanting a more traditional warm white than natural / cool white light as well?
Have you tried reflecting light off the ceiling, from, say, warm white LED floods?
You could try modifying the colour of the light with filters - rose, yellow, pale blue (daylight), amber, one blue one amber next to each other mixed to make white?
There are also UV filters available which filter out the UV part of the spectrum, if that is the problem, or you could try a clear filter and tell the customer it filters out all the nastiness, or make up a frosted light box with LEDs of a similar CT to tungsten, and simply tell them the light is "sourced organically and ethically".
buy them some bloody candles or install gas lights. :punk:
Reply to Low voltage halogen equivalent??? in the UK Electrical Forum area at ElectriciansForums.net
Hi I have two lighting circuits of 5 x low voltage halogen with individual transformers for each lamp.. to try out the new 240volt GU10 LED's...
I have 5 x 5W LEDs connected to a 12V transformer powering the lights in my kitchen. The transformer is described as 20 - 60W so at 25W I'm above...
We are steadily replacing old incadescent, CFL and halogen bulbs in our house with LED bulbs. They tend to be the 2700k for the warm colour. We...
4K
Hello - I am,as you will notice new here. I hope that I can get some definitive answers that are clearer than I get on-line and talking to 'those...
Hey so just been to see a dad from the little daughters school class who asked me to have a look at his upstairs landing light pendant as his mrs...
