Discuss low voltage spots in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
depens what you mean the 'same circuit'?
do you mean the upstairs lighting circuit,
or all fed off one lighting point in the bathroom?
sorry need further clarification !
"point "is a very general electrical term (sorry in advance shakey)
are you intending to put all lights wired into one ceiling rose?
putting them on the same circuit shouldnt be a problem ,and running them through the switch shouldnt be either
as long as you comply with section 701 you should be fine
hi i have 4 lights in the bathroom on the same circuit the 2 over the bath i want to be low voltage and the other 2 i want to be 240v gu10s is that ok to do that
sounds fine to me , i advise that the lv's are ip rated and sheilded ,you dont want to be in the bath if one of the gu10 explode!!!
coincidently im replying on a different thread at the moment with a similar topic
Reply to low voltage spots in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
Old two core cable in a lighting circuit with no cpc at any point All points had metal fixtures and fittings class1 At two points the live loop...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
