Discuss Magic eye info in the Home Media Centre Forum area at ElectriciansForums.net
M
mickys86
Wondered if someone could help me out, customer I do some work for has asked if I can run hd cables from the corner of the room to the tv that's going to be on the wall (5m). They want to be able to connect the blu-ray and sky box to the tv and keep them hidden away.
My question is how does the magic eye work in all this? I'm fairly sure I need to run coax for the magic eye for the sky but how does the bluray connect into the equation?
Please ask Any info you may need that I haven't put here
Many thanks
Michael
You can buy infra red receivers that control any IR device. I asked the same question a bit back but in the end only Sky box is controlled via Magic eye and not any other devices.
Yes agree their is a coax output from the back of the sky box that sends a voltage down the coax to plug in unit that fits in your coax socket on the remote tv.... this unit has a fly lead with an infra red receiver on it to pick up the remote control. This sky coax output requires switching on from within the sky service operators settings.
Reply to Magic eye info in the Home Media Centre Forum area at ElectriciansForums.net
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
I'm doing a college design project and need to choose a suitable range of circuit protective devices for the whole contact. I've chosen and...
