Discuss Magic switch in the UK Electrical Forum area at ElectriciansForums.net
Has anyone else come across what the police called a magic switch. A friend who rented out his flat found one when he evicted tenant who was growing special plants. I won't say how they done it, but they bypassed the meter and put in a normal light switch in between meter and cu so could choose when to have meter reading electric. Until you took front off the cu you wouldn't even notice it.
I have seen one at a farm that previous tenant had used for growing it was on a 3 phase and about 10m of 25mm tails going to a single phase cu with 2 main switches one at each end! Turn one off and the other one on and bingo at the other end it came out do a block before the distributor cut out and was difficult to spot. The thing is the doggy supply and the real supply where on different phases so if both where switched on at the same time bang!
As far as I could see from the pictures he showed me yep a normal switch. The earth bar was connected to the neutral at main switch, then only a 2.5 mm cable was going to switch with main neutral also going to switch. Didn't get to see it first hand. Don't know how it didn't blow.
Round our way,they just come off tails by self-tapping a link direct to cable,presumably with an insulated cordless...Also the dudes in the "plant" job,don't switch meter as if the meter reader is in the building,the meter is NOT what he will be noticing...
wonder what muppet fitted that. it's a bloody abortion. and i don't mean the bypass, the whole CU is a mess.
I have seen much worse than that, okay it is pretty carp, especially as all cabling is crimped with yellow lugs regardless of the conductor size lol, but although tatty, I would say it was just carp and no more, I am suprised you guys have not seen anything worse than that, one board I looked at once had 18" of slack on every conductor and the cover would bearly fit lol, this comment does not include the appalling neutral conductor crimped from a 25 mm2 down to a 2.5 though lmao hilarious
Ha ha, perhaps he was planning on replacing it again lol.
Reply to Magic switch in the UK Electrical Forum area at ElectriciansForums.net
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
I am a builder who is renovating a rural property. A smart meter is due to be installed. It would IMHO be a good idea to get a rec switch...
Hi I don't know if I should ask it here or the main electricians forum. It's about CU change and the work around it and the CU change will be done...
11K
Hi Guys I have been following this forum over a number of years reading endless discussions and picking up things along the way. I am a JIB gold...
