J
johnosman
I've just been testing a block of flats where the main water supply is plastic and goes through the block in plastic pipe, the issue is that all the flats are then fed via a meter and copper pipework. Should there be a main bond to the closest copper pipework to the main water intake and this then joined to every subsequent branch off of the plastic pipe?
