Discuss Main Bonding question in the Australia area at ElectriciansForums.net
M
Matt
Hello, hoping someone can help........!
One of my customers has just split there large house into 3, New supplies for the new (two) flats has been installed, however the water supply remains the same i.e. there is still only one stop cock for the whole house. So do I.........Request that each flat has its own water supply sorted before seperating the wiring OR run 10mm to the stop cock in the main house OR clip 10mm on to the point where the water enters the flats even though they have no stop cocks??????? if you can help please do
Cheers Matt
As it is at the moment I'd run 10mm from each flat to where the stop cock is located & lable each with flat numbers.
But there could be allsorts of problems with paying the water bill anyway, so I'd also suggest to your customer that the water needs metering individualy to each flat.
Reply to Main Bonding question in the Australia area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Not sure on this one. Mains water is coming up from the ground in lead pipe in bathroom. 2 inches of copper pipe before the stop tap. All...
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
