DSpark1
Hi,
need abit of help in regards to earth bonding.
I'm working on a building with 10 studio flats and all the plumbing is done in plastic pips apart from the terminations of the shower and the water heater.
the main incoming water supply is via a blue plastic pipe, which goes into a manifold and is then spit to the 10 studio flats via plastic pipes. i have ran a 10mm earth cable from my MET to the manifold, however havent taken an earth to the individual studio's as all the pipe work is plastic.
do i need to take a 10mm from the manifold to each studio? and if not then how can i prove i dont have to, as when i was speaking to the NICEIC they said you need to check the discconnection time using 230v/0.03A (being an 30mA rcd protection on the circuits at the board), which gives an aswer of 7666 ohms. But what does that mean? between what do i need to be gettin 7666 ohms?
also i am planing to use this building for my niceic assessment so i will have to no reason's for my doings and he will ask :S
thanks in advance
thanks in advance
