F
fire
i becam Part P registered 8 months ago, need to change a consumer unit do i need to call the distributor to pull the fuse as there is no isolator?
Discuss main fuse in the Electrical Forum area at ElectriciansForums.net
what seal ???Pull it! The seal was missing before wasn't it?
Not my words but the assessor from Elecsa when I first had my assessment!!
a bit of common sense there, always overrides the jobsworths of this world, i say.Electricity at works act would supercede any supply authorities quirks on this one. You are legally obligated to isolate the supply before you work on it. If you have no other means of isolation then pull the fuse under no load conditions of course. Your safety and others take priority, so stuff em.
exactly, and if u re-seal it the customer cannot pull it after u! therefore making the job as safe as u found it!
Reply to main fuse in the Electrical Forum area at ElectriciansForums.net
