Discuss Main protective bonding conductor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
Adz
Hi,
Recently i carried out a periodic inspection report. It was on a house that had a separate boiler house. The boiler house had a light, a few spurs for the boiler and heating pump. It was an oil fired boiler and i placed a defect on the report as the incoming metal oil supply pipe had no main protective bonding conductor to it. Am I right to defect this? One of my bosses said it wasnt necessary to defect it as "it was a separate building" however i still disagree. What do you think ? :confused:
seperate building = seperate supply = seperate test
if the oil supply pipe goes into the house it should have a bonding conductor run from within 600mm of entering the house and running directly back to the CU or MET
from the point of entry into the house is your concern, this is the equipotential zone in theory. but in your circumstance i would say that if the sockets are supplied from the house therefore they are a part of your inspection ande the CPC extends the equipotential zone and the tank should be bonded as it has the potential to become live under fault conditions.
the code 4 is a personal decision, you being the competent person are the duty holder throught the test/inspection
is there an earth spike on the tank or any of the supporting framework? if not i honestly think you'd be justified to add it as a code 1, bonding conductors are a neccessity, end of!
Reply to Main protective bonding conductor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
Disclaimer: I'm not going to attempt this job myself, I want a professional to do this job properly since I consider it non-trivial and need it...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
