Discuss Main switch bs numbers in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Gazthesparky
Having a brain fart at the moment could some one put me strait and help me out. I'm filling in an EIC and in the part it says main switch/ switch fuse part i'm stuck on which BS number to it put. i have a metal switch fuse so its that BS number i'm putting in. I don't know what to list as a BS number.
In the switch fuse there is a 2 pole isolator BS60947-3 is relevant but there is also a bs1361 Fuse holder and 60a fuse
so which bs number should i list?
cheers
BS EN 60947-3.. switches, disconnectors, switch disconnectors and fuse combination units.
7671, 60898, 60947-3, 4293, 3871, 1361, 1362, 5419, 61008/9......The joys of having these numbers embedded in your psyche is one of the true pleasures of sparking!!
Oh, can't forget 3036!
Reply to Main switch bs numbers in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
I've been carrying out quite a few domestic extension first fixes recently which involves providing a power supply installed from the properties...
