Been asked to upgrade an old Wylex fuse box to a modern consumer unit in a property, simple enough. But the property has a solar pv system installed . Having a quick look all I can see in the mains cupboard is a gewis isolator marked solar pv. having no experience with solar pv installs just wondered if changing the mains is going to affect the solar install?
All the inverter equipment and such is mounted in the loft. Unsure how the system is connected Into the house is it through the meter outside or the consumer unit?
Any advise much appreciated!
