Discuss Maintaining top entry fire rating/IP rating in the UK Electrical Forum area at ElectriciansForums.net
I got off my bum and did my AM2 in 2016 and it wasn't used then. But SY was???
Can’t see the point of having SY as part of the exam personally.
Be better off with data/Ethernet, heating system controls and trying to chase in a new socket to an old brick wall with lime plaster - no visible damage allowed! (Ok maybe not the last one)
MICC was common for fire alarms and industrial control gear many years ago. I guess the appearance of FP rated wire and the time/cost of installing pyro means it is fairly specialised use now. Shame, as it is practically immortal and looked fabulous if bare and polished up!
I would suggest that there appears to be some instances where its being ripped out - possibly unnecessarily, simply because the electrician of the day doesn't know what to do with it.
In all seriousness I think heating controls, solar pv and car charging installation would be far more beneficial these days than micc and sy
Spoke to one of the apprentices today, apparently he has done MICC as part of a college assessment, but it is no longer part of the AM2. I certainly remember doing it when I did the AM2. At least they have kept in steel conduit...
Even if you don't have the tools or skills, surely you can recognise an MICC cable??!!
Maybe not when you are out of your depth
Given the longevity of Pyro and the many different types of installation it has been used in over the years it is a bit daft that it is not even given a mention on courses these days
Given the possible problems of glanding that pyro properly I think I would be replacing that earth clamp with some constant force springs to clamp the cable to the sheath to maintain the earthing
Ripped out and replaced by inferior cable types is usually the norm
The number of times I've seen on forums rip it out and replace it with FP, FP is not and will never be a direct replacement for Pyro IMO
But recognising different cable types, their uses and how to handle them is surely a very basic skill whatever level you are at as it is not all T&E in the domestic setting as the OP has found out
Its a shame the way this industry has become, completely scoped and split into sectors, with that it has its consequences.
Reply to Maintaining top entry fire rating/IP rating in the UK Electrical Forum area at ElectriciansForums.net
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
Hi all So had some issues lately related to high current fittings .. dp switches mostly. A number of electric boilers of various ratings .. from...
So I had a ceiling repair done in my bathroom due to water damage. The neighbors toilet above me was leaking for who knows how long. Mold...
