Discuss Making a 4 bulb lamp - Newbie in the The Welcome Forum area at ElectriciansForums.net
Hi,
I'm Rich I'm 39 and currently unemployed. I am a good ish DIYer and have basic knowledge of wiring. Love building things out of wood.
I have been tasked with making a simple 4 bulb plug in lamp for my wife's 'art' project. I need wiring and safety help.
It will basically be 4 23w bulbs in batten lamp holders, in a row, attached to a board, wired in parallel with a 3A plug attached.
Was planning to use lamp holders like this. Loop-In Batten Lamp Holder - https://goo.gl/SVwkki.
My question(s) are..
1. I was confident these would not need to be earthed as they are plastic fittings. Is this correct?
2. Can I just wire each lamp holder to the next by twisting and connecting the wires? Will be wiring in parallel.
I'm sure I have got some wording wrong and I apologise. Please help.
Welcome to the forum mate.
1. These lamp holders will come with terminals to connect to. There will be an Earth terminal. Please use it.
2. Use the terminals to connect the wires from each lamp holder to the next.
Post pics of what you have done so we may be able to give more advice (if needed) once you have done it.
Those batten holders have no pattresses to separate conductors and terminals from a combustible material (wood). How will you provide cord restraint from the final connection.
Will use 4 of these MK Cordgrip Lampholder BC White - https://www.NoLinkingToThis/p/mk-cordgrip-lampholder-bc-white/18465 instead of other style batten lamp holder.
Will mount each one and the splice all cables together with cable plugs in a plastic junction box.
Will that be ok instead?
So just to confirm is the below pic what you are intending to make?
and you are going to use these..
The batten holders you link to are not generally very suitable for surface wiring, the cable is intended to enter via the back of the unit.
Perhaps a two part base with a cable channel at the back.
You would use the terminals and include the earth. If wiring in flex ideally the flexible ends should be ferruled for strength.
Wiring would be from light to light to light, parallel wiring, though the whole cable would appear to be series.
It should be fairly straightforward, but mildly technically demanding to get right and safe, if the cables come in from the back then the batten holders would be fine, if the cables are surface on the front then you would need to make up a threaded lamp holder with a side entry coupler (with cord grip if the cables are not fixed in place) and a threaded back plate to mount it on the wood. If you are using brass then you may need an earth tag if there is no earth terminal.
I meant 13A plug. Using plastic lamp holders. I have attached a basic drawing showing wiring plan. Birdseye view. 4 lampholders mounted on/through wood. Is this correct? Many details missing. This is so I know the wiring is right. Thanks for everyones help.
The wiring intent is right, live to live and neutral to neutral, light to light.
You will find that the wood needs to be thin to be able to hold the lamp holders in place with the fixing ring, the lamp holders only have space for one cable so I would suggest perhaps attempting to use flat two core cable, ensure the cable is gripped and enclose the back of the structure.
A 13A plug with a 3A fuse is correct.
Have purchased 4 BG batten lamp holders with back plates.
My wiring diagram for them... (couldn't fit 4 on picture!)
Will be 4 lights, in a row, on a board or batten, with a 13A plug 3A fuse.
Note that pendant wires are both white.
Can anyone confirm this is correct.
Thanks.
Reply to Making a 4 bulb lamp - Newbie in the The Welcome Forum area at ElectriciansForums.net
Hey all. New here and new to 3 phase. I had some electric experience on set in Los Angeles as a gaffer for a couple of years, but it was mainly...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hello, I have ended up with 3 identical lamp stands (long story), each with one E27 bulb holder. What I would like to do is put all 3 bulb...
Hope this is the correct forum for this. I have a chandelier that holds 18 bulbs, it's not in use since ages ago and I was planning to restore...
  • Locked
Hi I've just purchased a metal framed ceiling light from AliExpress and I am concerned that it has no earth connection or double insulated...
