E
edrobbo8
Hi guys,
Have to make off some 95mm lugs onto an old Bill main switch, which has 160A fuses. There are 4 terminals with an M10 dome head bolt with a square shank for the 3 phases and neutral, and there are currently 2 lugs on each bolt, 1 feeding a main dis board and 1 feeding a new switch fuse that goes to a seperate control room.
We need to get a third 95mm lug on to each terminal, would it be acceptable to put two lugs on each bolt secured by a nut, then our 3rd lug onto the bolt which will sit tight up to the 1st nut, and tightened up with another nut? Hope that makes sense!
