La Poste
- Reaction score
- 126
If you came across the situation where you had to add a piece of cable because the cable you were dealing with was not long enough what would you use?
I have two options at the moment either dig the whole drive up and replace the entire cable lengths to some lights at the entrance to a property or add to the cable so they can be switched on/off where the owner wants.
What is your preferred method of permanently joining cables?
The joint will not be accessible once it is put in place.
Thanks.
Thanks.
