Discuss Makita BTP 140 in the Electrical Tools and Products area at ElectriciansForums.net
singlerider
So, I'm just wondering if anyone's got or used one of these little fellas?
Currently I've got a cheap and cheerful Ryobi battery drill, as it was all I could afford at the time - and to be honest for the moment it'll serve the purpose.
However, they'll come a time when I want something proper, and I've been looking at this thing with interest - on the face of it, it certainly seems like a good idea - 4 in 1, combi drill and impact driver . . . sounds like a winner. Doesn't it?
Well, what looks good on paper doesn't always work in the real world, so I was wondering if anyone has come across one of these and how it shaped up.
I really can't afford to blow that kind of money on something that could turn out to be cack.
Ta in advance
Get one. I wouldn't be without mine now. I use it every day!
Sound, that's a pretty winning endorsement.
Battery life any good? I've heard 'things' about the new Li-ion stuff, dunno how much to believe. Also, what's it like for fittings and that? Don't you have to have some sort of special adapter to use normal bits in it (or something)
Cheers mate
Mate, it is the best bit of kit you will but. Highly versatile and the battery life is fantastic. As for bits - uses normal hex bits. Just buy it - you won't be disappointed.
Just bought one. I found the BTP140 4 function and BHP451 3 speed combi twin pack with 2x 18v 3.0 Ah Li-ion batts, charger and case for only £345!!!
Tool Chest Direct Search
£50 cheaper than the best next price for just the BTP140 with 2 batts!!! Struggling to find a 5.5mm masonry bit for the BTP140 though
Reply to Makita BTP 140 in the Electrical Tools and Products area at ElectriciansForums.net
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
As a young man, I was an electrician, but now I'm getting on, I am strictly DIY. I used to have a cheap old 900W petrol generator connected to a...
