Discuss Marking Neutral and CPC at CU in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
dixon9
Apparantly, where practicable, the neutral and cpc are to be marked or labelled at the CU. Those of you that do so - what method of labelling or type of markers do you use?
I use panel wiring cable markers. Get them in kits from RS.
They are available in plain white or coloured . The coloured ones follow the resistor colour code.
Hmmm, if I remenber from collage days, there is a rhyme to help you remember the order as well.:rolleyes: Dont think its postable !:eek:
LOL!
B Boys R Our Young Girls But V Go Without!
Those were the days! Supervisor ----es you a draw full of resistors and you had to put them all back in the right compartments!
What do you mean by marked or labelled?
For example, N1, N2 etc.... So you know what neutrals correspond to what lives (phases!).
Betty Brown Runs Over Your Garden But Violet Grey Walks. (Green is number 5).
regards
LOL!
erm...its now 'Lines' old chap
you are SOOOOO 16th edition:p
LOL!
Thats the one Dixon old chap, but it was V got wiser !
Happy Days !
Reply to Marking Neutral and CPC at CU in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I see they're introducing a new type of flat twin cable with a sheathed CPC. In my location there's no requirement to sleeve CPC/bonding...
Afternoon all. Was wondering, when cables are run underground using mole/tunneling methods, how do people get around the requirement to mark...
Hi! DIYer here. I have an MCB running to a cooker isolator switch. The RCD connected to this set of MCBs is tripping and isolating the cooker MCB...
Hi. I've read much about ac vs dc but can't find a 'simple' answer. If current alternates 50 times per second in a uk mains circuit, why do live...
