Discuss Marsh Industries MA1 high level alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Timbo
Supporter
Has anyone fitted one of these? The instruction sheet has disappeared. Just need to know which terminals to connect the float switch to.20190104_073450.jpg 20190104_073450.jpg 20190104_073450.jpg
Educated guess would be I/P 1 or I/P3,
20190104_073542.jpg Thanks Tel. Plug connections are Com, I/P 1, I/P 2. The black wire from 0v on pcb is connected to I/P 1.
I'll do a bit of trial and error. Logic would suggest Com and I/P 1.......
That hard wired connections looks a bit of a bodge. Was it supplied like that?
Yep, the mains flex on left, small black to the middle connector and the relay output to the beacon are all original.
Doesn't look like any strain relief on that mains cable either. Jeez I do moan a lot me.
I have to admit to removing the flex gland as it is mounted on trunking.
I connected the float switch accross Com and I/P 2, pulled the float from the chamber and the alarm went off.
Thanks, everyone.
Reply to Marsh Industries MA1 high level alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi, does anyone know of a way to fix a magnetic alarm contact to a plastic door which has a curved beading shape where the magnetic contact would...
