Discuss Max neutral/earth voltage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
Big Al
Hi guys,
It's been 10 years since I was a sparky so I am out of date with current regs. Can anyone tell me the max permitted neutral to earth voltage at a spur. I think it is 1.25v. Please help!
Pme its is required that on a permant install in fault condition nothing greater than 50v n-e
tempory installs and caravan parks/marinas/building sites nothing greater than 25v n-e (obvosioly not pme as this is not permitted on anything that has a safe n-e toch voltage of less than 25v
no volatage should be present on a n-e test if there is u either have bad insulation restance beteween n-e earth /bad wiring or a surge protector that has activated
i hope this helps
Reply to Max neutral/earth voltage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi, I've got a light with a ceiling rose in the kitchen. While rectifying some faults in the house I came across to the light and measure Neutral...
5K
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
