Discuss Maximum Cable Length?? in the Australia area at ElectriciansForums.net
V
videz6
can someone please help me with this question
There is a 40A BS88 fuse, protecting a 10mm cable with a 4mm Earth, it is wired to Reference method C, supply is TNS and it is protected by a 30mA RCD. What is the maximum length the cable can be?
(thats all the info i have! I haven't been to collage for couple of years now and cant remember how to do it )
find max zs then deduct ze wich will leave r1+r2 rearange formula to make length the subject:
r=mva x length/1000
so
l=r x 1000/ mva
that should work
thanks for that mate, but i dont know if it swa. how would i work it out? is it by doing the volt drop per meter?
Thanks,
Vidz
is it
45(amps) x 4.4 x 45(meters) / 1000 = 7.92 (which is just under the maximum 4% voltdrop)
is this correct?
sorry guys but i'm a bit rusty lol
Dont have regs to hand but guessing something like :
Ze = 0.8
Zs max for 40a bs88 = 1.35 deduct ze zs leaves r1+r2
1.35 - 0.8 - r1+r2 of 0.55
so r1+r2 = mva (for 10mm.4mm) x length (not known) / 1000
0.55 = 6.44 x L / 1000
rearrange to length = r1+r2 x 1000 / mva for 10mm.4mm
L = R X 1000/ MVA
L = 0.55 X 1000/ 6.44 = 85 METERS
thats what the max length for zs comes out at although a volt drop calc would need to be done also
values of resistence table 9a osg.
that would give the max cable length to meet earth loop value but would be too long to meet allowed vd
Maximum length according to volt drop on t&e cable carrying the full nominal current rating of the Overcurrent Protective Device at a nominal voltage of 230v assuming cables are not grouped.
1.0mm / 6A : 26m
1.5mm / 6A : 39m
2.5mm / 16A : 39m
2.5mm / 20A : 31m
4.0mm / 20A : 52m
4.0mm / 25A : 41m
6.0mm / 32A : 49m
10.0mm / 40A : 65m
16.0mm / 60A : 68m
just looked it up and its same formula from a simmilar worked example used in "practical guide to testing book"
zmax for fuse - the ze = R1+ R2
R1+R2 x 1000/ mva = length (Rearranged from R= mva x length/ 1000)
Cant see any other way of calculating without knowing the vd or the length.
Sintra gives a value of 10.0mm / 40A : 65m but need to see how he calculated it
(mV/A/M) * Ib * L / 1000 = VD
Rearanged.
VD / Ib / (mV/A/M) * 1000 = L
Max Vd = 11.5 V
Ib = 40A
mV/A/M for 10mm T&E = 4.4
11.5/40/4.4*1000 = 65.34M rounded down to 65M
VOLTAGE DROP
The maximum permitted volt drop measured from the incoming supply is 3% for lighting circuits and 5% for all other circuits. p358
230v x 3% = 6.9v
230v x 5% = 11.5v
Thought I was going mad for a minute and somebody had removed my post.
This question was also posted HERE which is where I replied to it.
Ring circuit
4 x (Max Zs - Ze) ÷ ((R"1 + R"2) x Cr)
Radial
R"1 + R"2 = Resistance per meter of Line & Cpc conductors
Cr = Correction factor for conductor operating temp of 70°C
So lets assume your Ze is 0.8 (max for TN-S). The max Zs for a 40A BS88 fuse is 1.35Ω and the R"1 + R"2 of 10/4.0mm² cable is 6.44mΩ per meter.
The calculation would be:
(1.35 - 0.8) ÷ ((6.44/1000) * 1.2) = 71m
However most maximum circuit lengths are limited by Voltage Drop and the voltage drop of 71m of 10mm² cable carrying 40A is 12.5V which exceeds the 11.5V (5%) maximum VD for a power circuit.
VD = mV/A/m x Length x Current
VD = (4.4/1000) x 71 x 40 = 12.5V
So you would need to work out the max length for Voltage Drop
Ring
4 x (Max VD x 1000) ÷ (mV/A/m x Current)
Radial
So for your circuit the calculation for VD would be
(11.5 x 1000) ÷ (4.4 x 40) = 65m
Reply to Maximum Cable Length?? in the Australia area at ElectriciansForums.net
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hi Guy's, I'm revising for my 18th amd 2 and came across a question that has me a little confused. I think its probably the question is badly...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
