- Reaction score
- 0
How much current capacity can handle in a 16 sq. Mm. Wire size in ac 415 volt supply?
Because i have 2 pump motors that will connect to a power source of 415 volts ac 3 phase; 1 motor is 5.5kilowatts and another one is 7.5kilowatts. Both motors will run intermittently and supplying different tanks.
If this motor runs together will the wire handle the combined currents?
