H
harry olee
In order to meet current regulation the maximum meter tail length should be no more than 3M and if over a 100amp fused switch should be fitted - is that correct.
(This guidline is not in the iet on-site guide except that this maybe specified by the distributor)
521.10.1 mentions that the tails should be insulated and sheathed or insulated and enclosed within containment. What should the composition of the sheathing be, 25mm cable comes with a grey plastic sheath.
eg:
BASEC approved PVC insulated and sheathed, single core stranded cable to BS6004 Table7. Commonly used as meter tails for connecting consumer units to the electricity meter.
This cable does not require enclosure - is that correct.
eg:
