Discuss MC4 Connector/6mm Cable Query in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi Guys & Girls,
Can anyone help. Im trying to find evidence that standard MC4's wont fit 6mm cable. If fitted it will result in Riso faults, loss of generation etc.
Reason being using a standard MC4 your unable to tighten the gland up fully, if tightened to much it cross threads making the ingress of water even more so.
Can anyone help me find evidence of this or knows where to point me in the right direction?
Thanks for your help in advance!
the gland is designed to tighten to the cable and no further, as long as it's tight and the cable can't rotate in the gland then it's water tight.
Reply to MC4 Connector/6mm Cable Query in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Morning all So the site I'm based at recently had some work done (think partitioners). This package of work included electrical. This was...
8K
Hello there! Could anybody help me with this query please, I am not sure where to look up the information I need? As I understand it, cables...
4K
Hello, I'm hoping someone can help me with a problem I've come across on behalf of a colleague. A single phase PV system with a 6kW inverter has...
  • Locked
5K
Iv been asked to wire a separator (portable to go to different farms and separate water from slurry) to a 3phase 40 kva generator. The separator...
