Discuss MCB replacements, "To P or not to P, that is the question". in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
pmcsparks
Three situations on which I'd appreciate comment.
  1. Replacing S-E fuse carriers (BS3036) with plug-in MCB's (Wylex or whoever) in older CU's.
  2. Replacing cartridge carriers (BS1361) with plug-in MCB's (Wylex or whoever) in older CU's.
  3. Replacing failed MCB's (BS EN 60898) on a like-for-like basis in newer CU's.
Should any of these be treated as notifiable?
You didn't alter a circuit and you didn't add a circuit, like for like is allowed, so I would say no ( though I am not a part p sparky )
Shocking_eg and farmelectrics maybe both missing the point.
Replacing the CU is most definitely notifiable.
I'm not 'Part P' registered and LABC fees round here are ÂŁ250 for 'Part P' work.
If you give them your quals list (and copies) they should do a "reduced rate", still around the ÂŁ150 mark most places (ÂŁ140 it used to be here).
I would say no; there is no requirement for notification.
The only thing you will have to wach out for, is that the Zs are low enough for the MCBs on lighting circuits.
I thought that was a question only us older sparks faced after waking up in the wee small hours on a cold winters morning whilst standing looking at the toilet bowl.:frown:
Not in my neck of the woods. ÂŁ180+VAT for anyone, regardless of qualifications. Not that it affects me, as I'm part P registered.
i wasnt talking regarding the part P side of it, reading the OP's post again i see what he means.
but i was just clearly suggesting that why pay out for ÂŁ100+ for plug in mcb's when you that amount of money could buy a new CCU ?
no real advantage of adding plug in's other than the easy reset as compared to BS3036's RW Fuses.
each to there own :)
i dont want to start any more bitch fights on here ! lol
The requirements for issuing an EIC or a MWC in no way relate to whether circuit characteristics are altered.
The requirements are whether alterations/additions to a single or multiple circuits are to be recorded.
An EIC may be issued to cover a single or multiple circuits, a MWC can only be issued for a single circuit.
In the OP's case, they could issue a single EIC to cover all circuits altered, or multiple MWCs, one for each circuit.
Reply to MCB replacements, "To P or not to P, that is the question". in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
Doing one more of the flood of EICR today on a rented property before a tenant change, but ran into a slightly interesting case so would...
12K
Hi, Before I begin my tale of woe, I have my tin hat ready! I'm retired from the trade, I started out just as the 16th came in and had a rather...
4K
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
E
As I lack practical experience and recently failed to impress NICEIC into Registering me, I thought I could build my own test rig then test the...
5K
