Discuss MCB trips ONLY when open in one go all lights together in the The Welcome Forum area at ElectriciansForums.net
zwizwi
I have about 50 led spot lights + more light , all together is about 400w if I open them all in one go together, then the MCB [=6 am] trips immediately, but if I open them one by one I have no problems at all !
I tried to replace the MCB with another 6am and it did the same, but when i replace it with higher no.[e.g. 10 am] then its Ok.
Do you have any idea why it's happening, is there a solution without replacing MCB or wires?
Thanks a lot
Reply to MCB trips ONLY when open in one go all lights together in the The Welcome Forum area at ElectriciansForums.net
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
