Discuss measuring (R1+R2) on a radial with a DOL in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
S
s1m0n
Hi eyeryone,
Has anybody got the best (simpist way) of measuring a radial circiut with a DOL controling a Fan, This is on a Rig at college, on which I will be tested on next week. I want to be able to prove polarity at the same time, as in a light radial for example.
Thanks in advance.
When it comes to testing continuity on a circuit with an inline p.b direct online starter (dol), you could always bypass the starter (connect it out) and test between l-e at the end, ie fan, or you could use croc clips at l-e at fan and manually holding in the contacter as this creates the link to provide continuity.
My prefered method would be hold in the contactor.. but that all depends on the assessor whether he likes that idea.. Might be worth just confirming this with a college tutor beforehand to confirm.
Hope this helps..:)
Reply to measuring (R1+R2) on a radial with a DOL in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Looking at the EICR form. GENERIC SCHEDULE OF TEST RESULTS Looking for clarification on R1,R2,Rn versus r1,r2,rn continuity values. I have...
7K
For example the house today had two lighting T&E in the same MCB. I know it's fine, but as I test both 'radials' where and how do we enter them on...
Hi Im an apprentice and just wanted to clarify domestic style wiring since i work industrial and don't deal with conventional wiring. in college...
