Discuss Mechanical protection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
D Skelton
Mentor
Just out of interest, how many steel capping lengths stacked on top of each other would you consider to be suitable to provide mechanical protection to switch drops on non-RCD protected lighting circuits?
I've always been lead to believe that 3mm of steel is thick enough to be defined as mechanical protection against screws and nails which by my measurement would make it about 5-6 steel capping lengths stacked. Would you stack more or less? Would you even consider it suitable?
And before you mention it, lets say for example that steel conduit is out of the question.
Debate... :D
As it's layered perhaps some could be surplus to requirements. A penetrating object would have it's velocity reduced by the first layer, then the second slows it some more etc etc. Wouldn't like to try it though
I suppose you could judge "how many" whilst fitting
If you can easily bang your fixing nail through the sheathing you may need more :smile5:
Fixing nail??? Steel capping??? lol
No, I would probably drill the stack me thinks and combine with screws and plugs :D
Ah,you are now copying my usual method,but we need to use capping nails for the considered opinion of "how many"
Bringing drills and such to the issue would be infecting the experiment with high technology, that would render the result invalid
How can steel conduit be out of the question , but 6 layers of capping is a considered alternative ?
Fit as many as you want lol , bs7671 still wont recognise it as proper mech protection ;-)
its not just thickness either , conduit steel is considerbly harder than capping tin-foil.
Coz it is :D
6 layers of capping would only be about half the thickness (overall width wise) of the diameter of 20mm steel conduit. If mounted on a wall, it is just as thick as 1/2" plasterboard and can easily be plastered over. Steel conduit would protrude too much to plaster over.
bs7671 still wont recognise it a proper mech protection ;-)
Correct me if I'm wrong but as far as I'm aware, BS7671 has no guidance for what can and can't be considered mechanical protection, only that mechanical protection must be suitable for each individual situation.
Hence why I said 6 layers. I've used 3mm steel plate to protect cables before and you aint never getting a nail through that unless you're using a Paslode! Then again, with a Paslode you could quite easily penetrate galv conuit as well :D I just wondered if enough capping was stacked together to an overall thickness of 3mm, surely that wold be the same as 3mm plate steel anyway?
and youre wrong about bs7671 guidance on mech protection.
dont want rcd's ? then its EARTHED steel conduit or swa. thats your lot.
gonna be earthing your 6 layers of capping then ?
thought not lol.
Epoxy resin between capping sheets and you'll have the poor mans version of Chobham armour... :lol:
stop being lazy and chase out the conduit drops.
we both know thats the real reason lol.
Ah, with regards to that, the block was waaaay too thin to chase, hence why I asked.
With regards to the other situation, I was thinking of CU changes that involve moving the CU thus rendering the cables buried in the wall out of their safe zone.
- - - Updated - - -
option b - swa
I never would, tis way too easy to penetrate with nails IMHO
Edit: I should add, these are hypothetical future situations that could potentially be made easier with steel capping than when I've been faced with these same situations in the past.
Reply to Mechanical protection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, My first post so hopefully I am correct in posting it here. My question is, I am thinking of an IP rated outdoor socket for the back garden...
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
Hi, I was hoping someone with a little more insight might be able to shed some light on a potential issue I have, as I can't seem to find another...
7K
Disclaimer: I'm not going to attempt this job myself, I want a professional to do this job properly since I consider it non-trivial and need it...
