Discuss MEGA Test leads Compatibility in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
John-
Anyone know which Mega MFT test leads are compatible with the Kewtech R1 and R2 plug please, or some way to frig the connection?
It seems to work with 4mm push on leads. Wondering if my probes will actually just push in?
John
use any leads that work with the kewtech. megger MFT will work with any 4mm leads. i have found that the megger leads won't work with lightmates. PITA.
Reply to MEGA Test leads Compatibility in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi all, hope someone can help 😊. I am looking at running a transformer extension lead behind my dot dab plasterboard wall. My wife bought a Led...
I recently purchased the Flir VP52 and it's really well made. Even if you don't like the things, it doubles up as a pretty good torch. They're...
Hello, I am updating an old wall outlet with a new. Here is a link to the old and new outlet - see below. On the old outlet there are 2 neutral...
When I set up my Christmas outdoor lights this year, i realised that I must be using the wrong transformer as half the lights on the string are...
