Discuss megger 1502-2 in the Electrical Tools and Products area at ElectriciansForums.net
E
eifion
does anyone know why the megger 1502-2 is not a 17th edition tester i,ve thinking of getting a new multifunction tester but i don,t want a 16th edition i,m drawn between fluke and megger
I thought it was with the exception of auto rcd feature?
why not get the 1552 or 53 if youre looking for new?
also any1 use the powersuite, whats it like for stand alone certs and bluetooth capability on the 1553, im about to replace my 1552 but not sure wether to bother with the 1553
Agreed if you are going to spend that sort of money try and stretch to a 1552/1553 if you think that you will be doing a lot of testing then the 1553 with bluetooth would be better as you can download and print making your pen redundant.
Chris
I've got the 1502-2 brilliant never missed a beat, though if I were buying from new again would definatly try and future proof myself by getting the current top of the range model
Hi Eifion
All the Megger MFT1500 Series are 17th Edition compliant, which includes the MFT1502/2
Regards
Megger Technical Support
Reply to megger 1502-2 in the Electrical Tools and Products area at ElectriciansForums.net
Hi I currently have Megger MFT 1721, I am looking to buy the megger tester attachment for EV charging , does anyone knows if the MFT 1721 takes...
Bloody specific fitting megger test leads! I've lost 2 of my megger probes now. I have plenty of crocodile clips and the long, thin, bendy probe...
Hi I’m just starting to do ev chargers so it’s looks like I need new tester. I currently have Megger 1711. So I can’t do a 6ma rcddc test. I...
Chaps - having problems with a new Megger MIT420/2 insulation/continuity tester 'oscillating' and failing to give stable resistance readings in...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
