Discuss Megger MFT1730 FORSALE in the The Welcome Forum area at ElectriciansForums.net
Megger MFT1730 with Bluetooth.
Calibrated until sept 2018:
Used, but great condition. Comes with all accessories.
Wanting £600 Ono
Some spec info below (taken from Tester.com)
Insulation testing at 100V, 250V, 500V and 1kV with adjustable alarms
200mA and 15mA Continuity tests
2-wire no-trip & high current loop testing with Zmax and R1+R2 values
Polarity test
RCD ramp test
Phase to phase loop test
RCD auto test & programmable tripping current level
3 phase RCD test
3 wire earth resistance test with 25V and 50V output & ground noise voltage check
Phase rotation test
TRMS 10V to 600V supply measurement range
Auto-start tests on continuity and loop resistance – no need to push the button
Dual display shows loop resistance and fault current results simultaneously
Dual test buttons for left or right-handed operation
Memory storage of up to 1000 measurements
Test lockout
Safe contact detector
Live circuit warning
Auto discharge
Analogue arc display
Bluetooth interface
Remote switch probe included
Rechargeable batteries
Weatherproof to IP54
CAT IV 300V safety standard
The MFT 1730 has a balanced neckstrap for hands-free operation with a TEST button on both ends of the tester for either left or right-handed testing. The large character dual display with backlight allows for two parameters to be shown at one time and colour coded range selection dials make this an intuitive and straightforward multifunction tester to use. The rugged design and IP54 rated rubber moulding of the MFT1730 allow the instrument to withstand tough conditions and heavy handed treatment. Together with a CAT IV 300V safety rating the Megger 1730 is a 17th Edition tester designed for safe using either inside or out. The carry case for this new Megger 17th Edition tester ensures the safe transportation of the instrument when travelling between tests and has extra space for the storage of tools, test leads and other extras.
Deliver for £1pm
2 years
(I’ve attached some pics)
Reply to Megger MFT1730 FORSALE in the The Welcome Forum area at ElectriciansForums.net
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
Chaps - having problems with a new Megger MIT420/2 insulation/continuity tester 'oscillating' and failing to give stable resistance readings in...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
Hi all I've got a Megger MFT1721 probably around 3 years old. Was working a treat but last 3 months whenever I attempt to do end to end...
Kewtech are at the later stages of designing the new MFT, like all the others will be made by Kyoritsu. The new one will be largely based on this...
4K
