Discuss Melting wires on kitchen lights in the UK Electrical Forum area at ElectriciansForums.net
hi there
Looking for advice. I have string lights in my kitchen and twice now, where the wires connect to the transformer they melt! I have the transformer connected to the mains which comes from the wall switch. Any idea why the wires are melting?
Poor connections spring to mind. If these lights are halogens then you might be overloading the transformer which would endanger the output cables, connections, transformer's internal fuse, if it has one.
Heat build up, are these wires in contact with the transformers? is there any insulation involved in the building fabric?
If these are the type where the lights are suspended from insulated cables, to which they connect using a pointed screw that pierces the insulation, the problem may simply be that the same method is being used at the transformer. I have seen kits of these where the transformer has pointed screws too implying that the cable need not be stripped, but the connection was not adequate for the total current of all the lamps resulting in overheating. IIRC stripping the cable and folding it back on itself was advised in the instructions.
If this is not the problem, the overheating resulting from bad initial terminations might have left the terminals too corroded to make a good connection at all, or high-resistance on the inside, resulting in repeated overheating.
Reply to Melting wires on kitchen lights in the UK Electrical Forum area at ElectriciansForums.net
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
