Discuss Memera 2000 40A rcbo required in the UK Electrical Forum area at ElectriciansForums.net
polo1
Hi all, what's the latest on Memera 2000 rcbos? I'm looking for a B type 40A - anyone have one? Or, is there an alternative?
Cheers.
Do you have mcb ? I replied to a post on this some months ago if you can find it.I think there was one of the mcb's that accepted a pod like Add to Memsheild 2.
It struck me as necessary to make the compatible rcbo fit . You are suggesting it is not a good idea ?
It suggests it is a non compatible device. It sounds like you have tried to fit a Memera 2000 into a Memshield 2. Memshield 2 fit Memera 2000 but not the other way around, I think I have that the correct way around.
Reply to Memera 2000 40A rcbo required in the UK Electrical Forum area at ElectriciansForums.net
Afternoon, I need to change a memera 2000 6amp mcb for an rcbo that is compatible . I believe the mentioned mcb are not made anymore. Anyone got...
I need to get hold of RCBO for old white plastic Memera 2000 consumer unit. They are now discontinued for the Memera 2000, only used ones are...
4K
Hi all I have been pulled up by Napit, not by my regular inspector. Used rcbo's on a rewire (usually do). Filled out cert to reflect this, with...
I’m probably going to look stupid here, but it will be worth it if I get the answer 😆, as I can’t fathom it out. I’ve never really thought of it...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
