Discuss Mercedes Vito with cycle carrier - NO TAIL LIGHTS in the Auto Electrician Forum area at ElectriciansForums.net
Steham
Hi folks,
Have a problem which had been driving me mad for months!!
Really need to get my cycle carrier lights working on my Vito towbar socket.
Have a 7 way bypass relay, and can get every light working, apart from tail lights!!
Have tried everything I can think of, nothing!
White wire is earthed on left hand side of 7 way relay, and towbar socket is earthed on the white wire too.
No tail lights....have checked wiring to the terminals in both halves of the towbar socket...no ideas!!
Please someone help meeeee!
Take it you have wired both tail light wires to respective connections in bypass relay ? Also check that your trailer board tail lights are not common. (linked together ). If so try one trigger only ,disconnect the black, or separate the link.
Also check the continuity of the trailer board wiring.
The socket on cycle carrier has separate wires for each tail light, so they're separate on the bypass relay too
Do you get any readings at the tail light terminals when they are switched on? Are the earths ok at the lamp holders ?
Is there output at the relay connections when switched on?
Have you used Scotch locks to tap into the loom?
Reply to Mercedes Vito with cycle carrier - NO TAIL LIGHTS in the Auto Electrician Forum area at ElectriciansForums.net
Hi all, hoping someone might be able to help a little, we got our daughter a renault twizy, but the headlights do not work. The side lights...
Hi I have had a TEB7AS isolation relay module fitted to my 2014 Skoda Fabia for many years and have had no lighting issues whatever when I plug...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
