- Reaction score
- 20
Hi
does anyone know what if any type of MCBs/rcbos are compatable with merlin gerin 3 phase boards.
Discuss Merlin gerin 3 phase board compabile mcbs/rcbos in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Schneider are Merlin Gerin and they also do Square D with the sprung 2pin plug in mcbs... these are molded to the same spec and are actually the same mcb but have a pin attachment added, remove the pins to get an identical mcb.
Paul if you have a bunker near where you are, I strongly suggest you get into it sharpish.The reason I asked is cause I'd seen Schneider ones that look compatible and are half the price so if they were compatible and they was no issues with using them, then I would of considered them.
Exactly, think about your last few posts closely, you will understand what I am reffering to if you really look at them.And why is that?
I'm asking for advice here, not to be talked down to
Paul if I wanted to talk down to you fella you would know, I am actually trying to get you to look at your last few posts mate, I would really like to try to stop you getting a fisting here, but alas I may be on to a losing battle, the posts regarding switching a single phase supply through a triple pole isolator was honestly ridiculous, I will not talk you down if you feel I am, I will leave the thread, but when the big boys start on you later I can only say you have been warned.I'm asking for advice here, not to be talked down to
Reply to Merlin gerin 3 phase board compabile mcbs/rcbos in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
