Discuss Meter and CU Board in the Australia area at ElectriciansForums.net
G
GStueyXR
What material do you tend to use for a new back board for incomer, meter and CU ?
Was gonna go with MDF as I have done several times before. But I am using this job for a NIC EIC inspection and I want no problems.
Is there a preferred wood?
I cannot see any regs suggesting MDF is a no no....
Can you confirm MDF is good to go? I would deffo buy a meter board as suggested, but I cant see any way of getting the meter off the present board without tampering with the upper seal.
I wouldn't touch the meter and head m8 just mount your new CU on the meter board and thats it, the NIC inspector won't pull you up on the existing meter/head not being mounted on the same board as the CU.
Reply to Meter and CU Board in the Australia area at ElectriciansForums.net
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
We are refurbishing an empty commercial building at the minute and I don't do commercial stuff day in day out so not entirely clued up on...
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
Hi there, long time lurker, first time poster here. Straight down to it.. A friend asked me to add some sockets and additional lights to a small...
