A
All4One_One4All
Hi everyone, I'm new to this forum and this is my first post, so apologies if I get anything wrong.
I do a lot of property redevelopments, and some landlords (myself included) prefer to put the elec and gas meters outside the property in meter boxes. This can cause issues, as often the only place for the meter boxes is much more than the 3m or so from the nearest place one can put a fused switch, never mind the CU.
Over the last 30 odd years, I've worked with a number of DNO's from NW, NE, Midlands, and SE England.
In respect of meter tails, they all seem to have varying rules. For example: in most DNO's, the maximum length is 3m and many DNO's are sticklers for this; whilst others will go to 5m, and a very few will occasionally consider the property and accept much longer runs if the tails are just switched and in steel conduit (32mm) all the way to the CU. Some allow a Switch to be placed in the meter box, and others absolutely refuse to even discuss this option, offering completely unreasonable suggestions (eg putting the fused switch in a tenants wardrobe such that if it fused no electrician would be able to get to it, and no other tenants would have any electric); suggestions I think that are deliberately intended to annoy.
So I have asked DNO's the following.
Sincerely All4One_One4All
- Why are meter tails limited to 3m or 5m or occasionaly longer? What's the maths behind this rule?
- Why can some DNOs make an exception when others won't?
- Why do some DNO's allow the Switch Disconnector (and even the fuse enclosure) to go in the meter box when most DNO's forbid it? (After all it's MY METER BOX), and quite frankly I think they are taking the **** trying to make themselves seem more important than they really are.
- Why do inspectors from the same DNO frequently submit very different proposals?
- Why have I yet to find a DNO that back up their rules with sound electrical theory, mathematics, and a fully calculated solution to explain why the meter tail distance is 3m or 5m or some other distance.
- And finally why does my current DNO allow numerous 1st floor flats over commercial ground floor properties to have meter tails exceeding 5m, and a simple SD installed in the meter box, when they refuse to even discuss this for a similar property of mine?
- No DNO to date has BEEN prepared to mathematically explain this distance, even though I have suggested the electrical equations and mathematical techniques that might be useful (from my 1st year B.Sc. degree, so it's hardly rocket science). They quote BS7671, but they can't or won't state the paragraph! Surprisingly, the DNO with the highest potential short circuit fault current allows the longest meter tail distance (of those I've worked with).
- Can anyone else on this forum provide the mathematics that I'm after?
