Discuss MFT adaptors for PV panel checks in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
Potential Power
Hi
I am looking at equipment at the moment. The metrel MI3125B looks like a great bit of kit, apart from one issue. The leads are connected via a non standard plug.
Test meter sell a set of leads that have mc4 connectors on them for about £20, but these have standard 4mm plugs, so will fit megger for example but not metrel. What solutions have people come up with to use a metrel for voltage tests on the pv panels.
Any other experienced solutions for the voltage testing would be welcome, plus experiences with various MFT's
I've made my own. Got a DC isolator, went to Maplins and got a couple of test post connectors. Fitted the posts to the cover and directly to the input cables. On the other end of the switch I put it a short circuit on the terminals.
In OFF mode - measure voltage at posts for Voc, in ON mode use clampmeter on cables for Isc.
You could buy these (Schuco) for about £90.
Do you have a pic of it you could send me please, and a link of where the schuco one can be puchased ?
Also which tester do you use ?
Sorry double posted for some reason !!!!!
Reply to MFT adaptors for PV panel checks in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, So I have decided to sell my Megger MFT1721 - See photos below. Originally I bought this for when I was doing my C&G 2391-52 course & then I...
Hi, how can I connect my Kewtech R2 lead to my Metrel MFT so that I do not have to carry the R2 reel with me whilst doing R2 testing? There was...
  • Locked
5K
Looking to replace my current generic test leads that are starting to show signs of variable readings. I also find the crocodile clips don't tend...
5K
I have bought some net led lights that are permanently installed outside. The problem is, I don't have an outdoor socket. And the socket in the...
4K
