Seanw
Hello,
Under the 17th Edition are you still allowed to use the outer sheath as earth ?
Discuss MICC Cable Outer Sheath in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It's MICC, the outer sheath IS the earth! you cant isolate it from earth due to how it's terminated.Hello,
Yes, as Telectrix said, the OP was checking on the suitability of the sheath as a CPC.
The sheath is very good as a cpc but not always so if also a combined protective bonding conductor,
Table D11 in Guidance Note 1 has 'effective sheath CSA' values for many commonly available MICC types.
2L2.5 for example has a sheath equivalent of 8.2mm.
Yes I believe that is why we are using 3 core this should be what has been priced because I don’t think 17th edition allows the sheath to be used but may be wrong.
thanks for the quick replies , i only ask as we have to install a 4mm 2C MICC cable and the spec calls for the earth to be used as the shealth. The pm says
as far as im aware you can use the outer sheath of the cable as long as you use an earth tail pot and not a standard one
Absolutely not true, earth pots were introduced for applications where glands were not used but a cpc connection was still required.
Conversely, good cpc continuity can still be achieved with a gland and standard pot.
It strikes me, that today's electricians are getting absolutly no training in MICC cables or in it's installation.
Yet install an installation in MICC today, ....and it will last forever, unlike any other form of wiring. Next they'll be calling it a ''speacialist'' wiring system!!! How times change, and as usual money is at the route cause of it!!
Reply to MICC Cable Outer Sheath in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
