Discuss MICC Terminating in the UK Electrical Forum area at ElectriciansForums.net
We used a lot of it fire alarm systems, before the birth of FP, the biggest multi core I ever made off was 19L1.5.
Made a handfull of them off not easy when the job spec doesn't allow joints so you have to have 4ft tails to get from the pot to the final connections
19 core MI not seen frequently for most installs, especially as it's about £100 per metre! 7 i sthe most cores I've worked with, 25mm2 the biggest csa.
OK but have you ever had to make a through joint in a 25mm twin, buried?
Reply to MICC Terminating in the UK Electrical Forum area at ElectriciansForums.net
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
A question if I may before I dive in. I have an old gravity fed CH system which thanks to members here in the past - works very well. It has a...
Hi all, I am an experienced DIY electrician and I just wanted to ask a quick question about something since I am new to this forum, if it hasn’t...
Hi All, I am a IT trained person, with 25 years experience and 5 years as an apprentice Electrical Engineer. I though I would ask advice...
