infinity
- Reaction score
- 214
I have a job using 8 console+ tubs, my question is can you use micro inverters with these? I can't see how you would fix the micro inverter under the module?
Can anyone who has used these shed any light?
Also what kind of ballast do you use? i will check with my structural engineer monday, but its only 2.6M from ground level with a meter from each edge, except the front where I'm hoping i can put them closer to the edge with additional ballast.
