Discuss Micro inverters in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
J
Jaycee
Hi all
What are your thoughts on micro inverters, do the initial costs warrant the increase in price over a standard inverter arrangement?
Enecsys are only good if you have a shade issue, I have them fitted on my roof, have to log on internet every time to see outputs.If no shade use a good quality standard inverter.
I am sure someone will explain how the solar edge are in comparsion
They seem to have really taken off over in the states, higher efficiency and greater yields due to 25 per cent higher outputs
You have to consider also other alternatives:
MicroInverters Enecys, Enphase, Involar, plus SMA and Power-One are also bringing them out soon.
or:
You could consider power optimisers - panel based MPP trackers that still pump out DC such as:
SolarEdge or Tigo
Any truth that many module manufactures are looking at installing microinverters onto panels as standard, and Market them as ac friendly panels?
Yes, and some are already embedding Tigo power optimisers
Because they rely on price to get the deal. See the other threads posted by consumers, where numerous times ones of these technologies was the right solution, yet they have sold/bought on price and so haven't given the customer what is actually needed.
Reply to Micro inverters in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi guys, I am new to the forum so be nice! I have this ABB (now Fimer)PVS-100TL 100kW inverter which cut off if there is too much solar...
Hi All, I hope you are doing ok. I have a question regarding the 24V system. I am going to build a pergola and I could install 4 panels on it...
Hi. I've recently passed an EESS course with LCL snd just done my first inverter and battery install with parts supplied by the customer. My...
We don't normally do PV, however I was called to a PV inverter with no power, 6 years old Found supply OK, however fed through a AC type RCD. PV...
Hello, My current 2.5kW Solar pv array is in a less than favourable position, but there is plenty of space to expand the array. I have an...
