Discuss Mid position valve and underfloor heating in the Central Heating Systems area at ElectriciansForums.net
M
Mork
Hi all, just installed a polypipe under floor heating system to an existing Y plan, the valve is a V4073A,with this system the UFH stat should independently operate the UFHeating from the existing central heating, the snag is with the time clock off and the UFHeating stat on both the UFH & the central heating come on, I've checked the wiring and I know Im back feeding the orange of the zone valve, but it appears that this in turn is back feeding the white (heating on). Q; Does this valve allow for back feeding? Is the valve itself at fault? Many thanks if you can help, cheers Mork.
No a 3 port mid position valve shouldn't backfeed from the orange to the white, otherwise the heating would come on every time the cylinder stat calls!
How is the new ufh connected in to the system both hydraulically and electrically?
I'm not sure exactly how its plumbed, the plumber assures me has the same system working fine elsewhere, electrically the call wire from the UFH control is connected to the orange.
Sorry you said you installed the system, I assumed you meant you had installed the system rather than just connected the electrics!
But either way did you not check how it had been plumbed in before connecting the wiring to ensure that your controls would be correct for the way it is plumbed?
So does this ufh have it's own programmer, stat and valve?
Sorry , should have made that clear.The sytem has a programmable room stat but no separate 2 port valve installed at the manifold, there is a 2 port at the cylinder end, this ive wired to come on/off with the cylinderstat.
So the 2 port is controlling the hot water in series (hydraulically) with the 3 port valve then?
I assume this is due to it being an unvented cylinder?
Is there no valve at all for the underfloor?
Sorry, yes there is a 2 port at the manifold, I think if im getting a back feed off the valve then it must this that's faulty----I think?
But you just said there isn't one there and there is an extra one by the cylinder which you connected to the cylinder stat?
Draw a diagram showing exactly how you have connected this system and then we might be able to give useful advice.
You can't just go assuming that something must be faulty, you need to test the system in all operating conditions and make an informed diagnosis. But first you have to understand how the system should work otherwise you'll be on a hiding to nothing
Reply to Mid position valve and underfloor heating in the Central Heating Systems area at ElectriciansForums.net
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Hi everyone, my house has an air-to-heat system that generates hot water in a boiler. This boiler is then connected to the central heating...
Hello Guys, I was wondering if any of you nice chaps could lend me some advice. So I have an open vented heating system with a 3 port valve...
I recently wired a heating system with a UFH8 manifold and an unvented cylinder.... easy. Well it threw up a few problems. Initially I had the...
